LTFT's "Disabled"...good, bad, or otherwise???
11 Second Club
Normally, I only have my LTFT's enabled while tuning VE. Have them disabled while doing MAF tuning and after tuning is done. Never an issue with WOT PE/AFR that way, obviously, but aside from VE tuning, for what other reason should I keep them enabled?
I had to richen up the tune a bit since adding a 4" intake tube to take advantage of the room I have after doing an electric fan conversion. It wasn't way off, but I did some tweaking anyway. Right now my LTFT's are + or -3 or less, MAF is 1% or less, and STFT's are generally + or -2 or less.
Is there any disadvantage to having the LTFT's disabled?
There seems to be absolutely no effect (one way or the other) on gas mileage or performance, FWIW.
I do not run LTFT's.
Only benefits IMO is if you develop an intake leak, it will compensate a richer mixture and also carryover to your Pe whereas STFT's will not. Since LTFT carry over to Pe, it could help if you had a nasty leak and didn't recognize it. And the other is to compensate for varying fuel mixtures with the "up to" 10% ethanol blends. I see swings as much as 0.5AFR in Pe from pump to pump.
11 Second Club
The main thing I don't like is that if you go WOT, and the LTFT's are way off, so will your WOT afr. From what I have read, PE adds or subtracts fuel depending on what the LTFT's have said it needed at PT...which seems to be counterproductive and erratic, if that is true.
I have never experienced fuel being added or subtracted when in open loop p.e. I always disable te ltft's and the stft's for tuning ve and maf, once thats dialed in I will enable them again and check trims.
Yep that is what i do.... Tune everything with the Wideband, then enable all the trims afterwards and then if the trims are off i tweak the switchpoints to bring them inline....
