LS swap not making anymore power past 4700 RPM
Old 07-29-2015, 10:07 AM
  #31
Formerly ScreamingL
George C....'s Avatar
Originally Posted by turbocdubs
so did a cranking compression test
1: 212 2: 220
3: 215 4: 235
5: 212 6: 220
7: 210 8: 215
thats alot of cranking compression and would point towards cam is retarded, but youre saying the dots are lined up
  #32
Formerly ScreamingL
curious what is timing and AFR
Old 07-29-2015, 10:17 AM
  #33
turbocdubs's Avatar
afr was 12.8 i believe and timing around 27-28
heres a log for you im not sure if it has everything you need on it but its a start.
The high rpm action starts a little before frame 160
everything seems to be in line.. im seriously debating on swapping in a new cam while i have the cover off
File Type: efi
Old 07-29-2015, 10:25 AM
  #34
turbocdubs's Avatar
exactly what i thought, i was hoping to find the dots off or something. But no im starting to think its in the cam grind itself, but i dont have a degree wheel to confirm
Old 07-29-2015, 10:40 AM
  #35
Formerly ScreamingL
ive heard of cams being just way off from advertised, Also for that size of motor the power is down anyways with a cam that size
your this far into it, yank cam out and go with another cam
Old 07-29-2015, 10:56 AM
  #36
turbocdubs's Avatar
any cam recommendations??
Old 07-29-2015, 11:38 AM
  #37
Formerly ScreamingL
what goals of truck
Old 07-31-2015, 05:31 PM
  #38
shuetuning's Avatar
This is an airflow issue for sure
steves86ta
07-28-2015 10:21 AM
Ketis
07-23-2015 12:37 PM
lxcoupe
07-10-2015 05:11 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: LS swap not making anymore power past 4700 RPM
