Low idle speed on startup/stalling
Hi, newbie here to forum. (I'm a corvetteforum guy) Seeking assistance with my wife's 2000 GMC Sierra 5.3 - (stock engine/driveline - for now) Truck has developed an occasional low idle at startup, which sometimes results in stalling. Off-idle/acceleration is fine. I have cleaned throttle body and IAC passage- no help. Truck is also not setting any codes.
Can anyone help ?
Thanks
Can anyone help ?
Thanks
You need to clean your throttle and if that does not fix it turn the idle screw out 1/2 turn at a time till the problem goes away. Your IAC motor is working to hard to control your idle.
OK, so it helps if I'm in the right forum. Thanks !
Turns out it was a faulty fuel pressure regulator.
The truck has a lot more throttle response too now.
I'm sure mileage will improve as well.
ARC
57
Feb 21, 2022 10:54 AM
colekill
14
Oct 11, 2016 11:56 PM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
smokeshow
Aug 23, 2015 08:23 PM
we have enough trouble with our own
LOL
