low coolant temp fault code
Old Dec 13, 2009 | 02:25 PM
Default low coolant temp fault code
I replaced the factory t-stat with a 160* t-stat, I didn't change anything else programer told me I wouldn't have to reprogram just for t-stat. but the check eng. light comes on with a coolant temp lower than factory preset code. called chevy dealership and talked to shop manager he said it should be doing this no reason to reprogram but I clear the code and it comes back on anywhere from 1 day to 4 weeks. any ideas????
Old Dec 13, 2009 | 02:48 PM
Dewey's Avatar
the ecu is freaking out because the engine isn't warming up as far as it's concerned. the only way to fix it is to tune it out i believe. i don't think it'll hurt anything the way it is though.
Old Dec 13, 2009 | 06:25 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yep, it's time to retune.
Old Dec 13, 2009 | 07:54 PM
fastgmc53's Avatar
14 Second Truck Club
Mine did it a few times after the tune.... I guess it learned itself maybe cause It hasn't in about a year... I haven't adjusted any temps either.
Old Dec 13, 2009 | 08:00 PM
viciousknid's Avatar
Where's the Beef?
If it is actually operating cooler you'll want to retune anyway so the pcm will stop feeding it more fuel. It is set to run rich until XXX temps and if it isn't reaching that temp it'll keep running rich.
Old Dec 14, 2009 | 06:20 PM
thanks for all the input guess i'll have to get a retune after i get different gears anyways
Old Dec 16, 2009 | 02:28 PM
fastgmc53's Avatar
hey villian I live just 40 minutes up I-75 from you... give me a pm next time you head to the track.. Nice to see more florida guys.
bk_cauley
40
Aug 17, 2018 05:45 PM
BCraven1018
37
Dec 20, 2016 11:46 AM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
Droptoplt1ta
Aug 19, 2015 07:34 PM
ullose272
11
Jul 17, 2015 07:22 AM
