Long Term Fuel Trims
Old Oct 3, 2008 | 10:48 PM
three83's Avatar
Default Long Term Fuel Trims
I noticed that my truck is getting 2 - 3 mpg less than it used to. This wasn't on a signle tank of gas, this has been the average of every tank of gas over the last couple of months and I fill up about once a week. I hooked up my predator and viewed real time live data just to see if anything was different than what it normally is. When I first had RWTD create the custom tune for my truck, the Long Term Fuel Trims were at zero (0) and now they are at negative four (-4). If I'm not mistaken a negative value for the LTFT indicates rich. So, if it is running rich, this could be the reason for the decrease in fuel mileage. I haven't made any changes to my truck in the last couple months, so I'm wondering what caused the change in the LTFT? Should I subtract some fuel to get the LTFT back to zero or should I do further troubleshooting to find out what caused this change?
It has not been to the dealership and it is not generating any codes.
I plan to have it dyno tuned in a few months from now when I buy headers and camshaft. I'd like to get the mpg back where it used to be until then.
Old Oct 3, 2008 | 10:49 PM
viciousknid's Avatar
Where's the Beef?
What are you using to scan? can you post a log?
Old Oct 3, 2008 | 11:04 PM
three83's Avatar
The Predator Programmer has a diagnostic section which allows you to view live data while driving. I think it is capable of recording the live data to a log file, but I will have to check tomorrow to be sure.
Is there any free tools that can be loaded on a laptop to do a scan and log it? I know there was for a friend of mines '95 LT1 Trans AM.
**Edit: You can get a log file from the predator. I will get it tomorrow and post it**
Old Oct 3, 2008 | 11:26 PM
Where's the Beef?
Cool. that would help.
First thing that crosses my mind is bad injector. but there are a few other things we should look at too.
Old Oct 3, 2008 | 11:39 PM
charcold-bowtie's Avatar
-4 does not indicate rich necessrily. It means the pcm is subtracting 4 percent fuel to keep the 02's happy.
On any given day your LTFT will probly fluctuate a few points. IAT, humidity, a bunch of stuff is in the equation.
On another note you want them to be anywhere from 0 to -4. That is a pretty good VE table if they are in that range. You want them to be negative anyway, positive trims are dumped on top of a commange PE value making a vehicle overly rich. IE, if at WOT your commanding 12.5 afr and the comp has a positive trim going in to it. It uses the appr injector to get 12.5 then dumps your positive trim on top of it for the safety of the motor.
2500ZL1
Jan 25, 2016 06:30 AM
therock
Jul 25, 2015 09:23 AM
Ammadien
Jul 22, 2015 08:50 PM
banker099
Jul 4, 2015 05:50 PM
