What is going on here? HPT
Old Oct 2, 2008 | 10:10 PM
04SilveradoMykk's Avatar
Default What is going on here? HPT
Man does my scan look weird... input?
2004 Silverado, originally A 4.3l v6. Original PCM now controlling the V8
.040" over 350 Small Block Chevy, the engine parameters are from a 2002 Gvan 5.7L and the rest of the tune was the previous tune I ran on the truck before the motor swap.
Four bolt mains
One piece rear main
Gasket matched & Bowl hawged Vortec heads
L31 fuel injection with updated spider
CFM-Tech 74mm throttle body
K&N FIPK
LT4 Hot Cam
Proform 1.6 roller rockers
GMPP Hydraulic roller lifters
Comp beehive springs
Comp HiTech pushrods
Flat top H345NCP hypereutectic aluminum pistons; .004" deck
10.2-1 compression
Summit Geardrive
Hooker long tube headers (with O2 bungs welded on)
MSD 6a
Accel coil
March Underdrive pulleys
Summit billet distributor
3200 stall locking torque converter
Motive 4:10 rear gears
Flex-A-Lite electric fans (stand alone)
And the exhaust is a 2.5" catless Y-pipe into single 3" mandrel bent with a Flowmaster Super 40
Video of how it runs/sounds like while making readings on this scan
http://www.youtube.com/watch?v=Yby9TFEfB7I
File Type: hpt
File Type: hpl
Old Oct 2, 2008 | 10:34 PM
hirdlej's Avatar
It's obvious to me you have a vacuum leak on the odd cyl bank causing lean reading. Check your exhaust system on that side for leaks, loose O2 or leaky intake manifold.
Old Oct 4, 2008 | 01:26 PM
sprayed8's Avatar
+1 on that. i had a very leaky header and collector for a while and even i didnt see that kind of lean reading. it looks like at one point in the beginning you were at like +75%. i'm surprised that beast was even running.
mhorn0817
Jan 26, 2022 08:48 AM
MikeD.
Sep 18, 2015 09:55 AM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
muncie21
Sep 7, 2015 09:55 PM
