Logging for converter slip, are the parameters correct?
Old Jul 25, 2015 | 12:41 PM
GMCtrk's Avatar
Default Logging for converter slip, are the parameters correct?
Found an old post from Atomic showing TCC slip as ((engine rpm)-(tranny input shaft rpm))/tranny output shaft rpm
I happen to be logging these parameters for a 3rd gear run from 80 mph (4679 rpm) to 117 mph (6183 rpm).
I just picked some random engine RPM's to check
engine RPM 4679
TIS 3804
TOS 3805
engine RPM 5085
TIS 3895
TOS 3904
engine RPM 5575
TIS 4093
TOS 4092
engine RPM 6183
TIS 5561
TOS 5566
This gives me TCC slip% of 18.7, 23.4, 26.5, 10.0%, respectively. These numbers just seem way out there to me. Does anyone have any logs we can compare?
Old Jul 25, 2015 | 08:00 PM
Vortec350ss's Avatar
I have data to share... I will respond when I get a chance... but its clear your converter is very loose and its very clear there is turbo lag lol
I know your lag isnt bad... but mine will flash its max and then for every rpm i grab from hat point on its getting more and more efficient.
Old Jul 25, 2015 | 08:11 PM
GMCtrk's Avatar
Yeah, the turbo isn't going to hit immediately like the blower, however, it does go from atmospheric pressure to 16 psi right at 1 second, per my logs.
Old Jul 26, 2015 | 07:15 PM
marlboroman71818's Avatar
what are you logging with?
here is my log with hptuners
File Type: cfg
Old Jul 26, 2015 | 07:19 PM
GMCtrk's Avatar
Im using EFI live, I cant see your log because I dont use HPT.
Can you tell me what your differences between engine rpm and trans input shaft rpm in 3rd gear WOT?
Old Jul 26, 2015 | 07:41 PM
without the converter being locked it @ 4803 rpm tcc slip is 371. when the tcc locks its 5200rpm and tcc slip is anywhere from 300-200rpm to 6000 or so
Old Jul 26, 2015 | 07:50 PM
GMCtrk's Avatar
First off, you are locking your converter at WOT in 3rd gear?
Secondly, why is the converter slipping still if it's supposedly locked?
Thirdly, assuming those numbers you posted are 3rd gear, at 4775 rpm, my TIS rpm is 3509 = converter slip of 1266 rpm versus your 371. Which converter are you using?
Old Jul 26, 2015 | 07:55 PM
yes locking it in third gear. trans and convertor are built for it jakes lvl 5 and circle d 3d. 2nd idk lol, trying to figure all that out. i have cut my force motor current in half across the board already . I think the trans isnt putting out the line pressure needed and I need to speak with Jake, its been like that since I bought the transmission a while back. I guess I should mention this is a 4l80e.
Old Jul 26, 2015 | 07:58 PM
GMCtrk's Avatar
What's the rated stall speed for the 3d? 258mm right?
Old Jul 26, 2015 | 07:59 PM
yea 258, it brake stalls @3000
