Lingenfelter lost sync
Old Aug 31, 2011 | 09:29 PM
Lucille's Avatar
Default Lingenfelter lost sync
After a short first gear romp coasting to a stop light idle dropped to 300 and truck stalled. Truck will restart and run perfect for about 20 seconds and the same thing happens again. The only thing I see under the hood is that at the time the truck starts acting up the 24-58 Lingenfelter module loses sync and starts flashing either 2 or 3 red following the green sync indicator. No SES lights and gauges appear normal. Any quick suggestions as the '09 is out with a busted ring land?
Old Aug 31, 2011 | 09:56 PM
blackcash's Avatar
Not the first box I've heard of going to ****.
Old Aug 31, 2011 | 09:59 PM
Lucille's Avatar
May have found the answer to my question. 3 red and 1 green=bad wiring or bad crank position sensor. My first thought was broken ground ( I hate electrical gremlins) I was just worried that the heat soak issue from the early models might be back given the 100+ ambient temp sitting in traffic. By the way if LPE is on here - slow them blinks down, they're hard to count.
Old Sep 1, 2011 | 11:37 AM
TimatLingenfelter's Avatar
Registered User
Default Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module
Normally when you see 3 red lights then a green light it would indicate that the crank sensor signal is not present. I would suggest checking the wiring and or replacing the sensor. Please email me your model number and when you purchased this item. tdyer@lingenfelter.com
Old Sep 2, 2011 | 08:11 AM
Lucille's Avatar
Tim - you've got mail
RONIN LSX
Feb 13, 2016 10:15 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
La Grey 1
Sep 21, 2015 11:07 AM
RONIN LSX
Sep 15, 2015 12:57 PM
