Learning to tune
Learning to tune
The dealership that I work for has ordered HP tuner pro so we can adjust for tire size. I'm confident I can handle that. The service manager has made it clear that's all that we will mess with on a new truck and we will not be a tuning shop. I'm fine with that has I don't feel comfortable tuning yet. I do however want to learn so I can tune my 2014 rcsb. If anybody has any info, tips, tricks or can point me in the right direction. I would be greatful.
HPT forum is full of info. Biggest part of learning to tune is to spend the time reading.
Learn one section at a time. There are a lot of parameters, and some do not make the difference you would expect.
There are tuning basics, ie tm removal, tire size gear ratios and shift points etc. Those are easy to learn and make a huge difference.
When you start getting into VE tuning, adding boost etc...that gets exponentially more complex.
The more you want or expect, the more reading and studying you must do.
That's what I've learned.
Best of luck
Best of luck
Best of luck
Best of luck
JFortner5
08-20-2015 06:13 PM
