LC1 is crap, Need recommendations on a wideband
Old Jan 14, 2007 | 08:38 PM
KySilverado's Avatar
What annoying "blips", did a bit of reading on their site and it looks nice. And damn cheap too.
The gauge will just freeze for about 30 seconds very occasionally. Most annoying is it will "blip" full rich or lean while just cruising along fairly regular. Very annoying especially at night. The data stream being fed to the logger is perfect. No blips. Appears to be a serial communication issue between the controller and gauge. Couple other guys have reported the gauge freezing on HPT fourm. PLX has suggested a couple things to try but didn't work.
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How exactly does it interface, I dont have HPT and dont have my Dynojet WB Commander hooked up in the truck yet to see how a WB interfaces into the cable so you can log your WB readings along with everything else. That PLX looks really good. Rhino, how easy is it to move form vehicle to vehicle? Thats what I would consider it for once I get a feel for tuning myself.
Old Jan 14, 2007 | 08:43 PM
CurtD's Avatar
10 Second Truck Club
I use an LM-1 works good. I get replacment o2's at the VW store. Chad at Greenlight >>>>>>>>>>>> sells them.
Old Jan 14, 2007 | 09:43 PM
TurboGibbs's Avatar
I've considered the LM1 but that PLX unit looks good and affordable. Any sponsors carry it?
Old Jan 14, 2007 | 09:55 PM
Rhino79's Avatar
9 Second Club
Very portable, I just put a 12 volt power plug on the power wires and other than that it's just a matter of installing the sensor and routing the wires into the cab through like the door jamb. Piece of cake I can have it installed on a vehicle and ready to go in about 3-5min.
dc_justin's Avatar
Hello Dave
I haven't had any problems with my LC-1, but if I were to do it again or needed to buy a different wideband, I'd go with the PLX SM-AFR.
Old Jan 14, 2007 | 10:12 PM
Derek @ EDO's Avatar
FormerVendor
yea, i was going to go with the LC-1 but have heard like a 40% failure rate over at tech,
interesting thread.
https://ls1tech.com/forums/poll.php?...ts&pollid=1739
Old Jan 14, 2007 | 11:54 PM
Wheatley's Avatar
Truck Sponsor
LM1 here,I use it ALL the time with HPTuners and has worked great everytime
Alvin's Avatar
You should see a LC1 vs. a Dynojet wideband.
PLX has my vote, so does AEM and Twin tech
Old Jan 15, 2007 | 07:05 AM
TurboGibbs's Avatar
Thanks guys. I'll be ordering a PLX today.
