LC-1 arrived...how did you all mount it, hardwire it in?
#62
Hopefully this clears up some things
Joe, I think there may be an understanding.
If you go to sae generic.txt and scroll down to the LC-1 you see this
# Innovate LC-1 WBO2
*CLC-00-932
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 7.35 22.39 .2 "({EXT.AD1}*3)+7.35"
*CLC-00-934
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 20.0 .2 "({EXT.AD2}*3)+7.35"
If you look at EXT.AD1 where it lists 0V and 5V I changed the line under that to 7.35 AFR and 22.39 AFR. I changed it from 10 and 20. If you look at AD2 you will see the stock settings that don't correlate to the algorithm AFR = AD1*3 + 7.35
Thanks
Michael
Hi Michael,
Those fields do not define the pid, they simply define the lower/upper limits that will appear on the chart or gauge (on the Dash A, B, C tabs) that this pid is assigned to...
The .2 defines how many digits after the decimal point will be displayed...
The pid is defined by the equation you see there.
i.e. the upper/lower display limits do not influence the pid... the pid is defined purely by the equation.
Let me know if that makes sense or not...
Cheers
Joe
*CLC-00-932
*CLC-00-934
Thanks
Michael
Hi Michael,
Cheers
Joe
*CLC-00-932
AFR 10.0 20.0 .2 "({EXT.AD1}*3)+7.35"
*CLC-00-934
Yet in Dashboard A,B and C and in Maps I do get values below 10.0 AFR. This expression does not seem to limit my lower boundary in logs that I have done.
The LC1 has worked very well for me. I do have a gauge wired in to mine as well.
#64
I bought a push in sensor from a 96 Camaro and a GM 2 wire pigtail. I drilled a hole in my STS intake tubing just before the 90 into the TB. I cut the wires going to the MAF and joined the pigtail to them and plugged it into the sensor. I found a grommet somewhere that fit and pushed the IAT sensor into it. It has never budged even at 16 psi. Works like a charm and I can reconnect the MAF if I want to because I left a few inches of wire on it's connector. The MAF is no longer in the truck.
#66
1. Skip step 6 (B3618), meaining leave PE enabled.
2. Step 7, set those three rows to 14.71 across the board.
3. Skip step 18, leave the MAF plugged in..
or you can follow the write up i did here
https://www.performancetrucks.net/fo...d.php?t=445995
#68
If you are following the Autove tutorial, these are the suggestions i make to that tutorial:
#69
Well that's interesting. In that case I really didn't need to buy the IAT sensor. I wonder why it states that the sensor needs to be relocated and wired up in the EFI live Autove tutorial. Maybe as it was written for a F-body setup and I believe they had a different MAF. But I guess I'll need it with a turbo setup anyways.
#70
Could you explain why you made those modifications? I would like to run an SD tune and forget about using the MAF. Mine is descreened and according to Justin it just isn't accurate at all like that. I've also read that running SD yields better throttle response as the MAP sensor is more sensitive to very quick changes than the MAF. But the downside is that it doesn't compensate for weather, altitude changes ,etc.
like i said, that is just the way i do it, everyone has their own style..
