L33 (LM7) to L59 conversion
Old May 3, 2006 | 11:40 AM
fly_champ's Avatar
Default L33 (LM7) to L59 conversion
I have an '03 5.3 L33. I have access to cheap alcohol.
An '03 5.3 L59 supports alcohol, so why not convert the L33 fuel system to match an L59?
The problem: Not enough details to figure out the conversion.
Information learned so far: ECM calculates ethanol percentage on the fly, the injectors on the L59 have different part numbers than the L33 (I assume higher pound rate), and the ECM's have different tunes. I don't have a tuner for this ECM, so I can't read the tunes I have found at HPTuner. I might buy their tuner if I know it will work for me.
I can only speculate that the only things I need to change the fuel system are some new injectors, and a new ECM tune. I assume that the gaskets, hoses, fuel pressures, etc are both the same.
Before I do something rash, like blow wads of cash on useless new injectors, I would like to have experts double check my information.
I have a great deal of engine knowledge, and alcohol knowledge, but not for this specific engine.
Since the alcohol option was avaliable for this engine, I think I can make a conversion. If anyone has access to the specific differences between the two engines, please let me know. Thanks.
Old May 11, 2006 | 02:31 PM
Yelo's Avatar
I've looked at doing the same thing.....but can't fine enough information to complete the picture. my best suggestion is to get a COMPLETE parts list from your truck and an L59 truck and compare the two to see what is different
Old May 11, 2006 | 02:48 PM
04sierra's Avatar
I believe that they have a different fuel pump. I have also heard that the fuel systems are slightly different because the ethanol can deteriorate the hoses and gaskets over time.
Old May 11, 2006 | 02:58 PM
RoninsDenali's Avatar
Differences that i know of. between the FFV L59 and the regular Gen3 engines is.
Slightly Larger Injectors, needed as E85's stoich ratio is lower than gasoline.
Fuel Composition/Temp. Sensor. - This is the critical component, this is where the PCM knows what kind of fuel its getting, how much alcohol is in it, as well as its Temperature (not a big deal with gasoline, but makes a difference with ethanol.)
Getting the fuel composition sensor hooked up to your current PCM i think is the greatest challenge you'll undergo during a conversion.
Old May 13, 2006 | 11:49 AM
tahoe's Avatar
Hi,
Take a look at this thread.
https://www.performancetrucks.net/fo...d.php?t=364850
The intresting facts come at the end, if I may say so........
Follow the links and I belive it will answer a few??? for you.
Br//
lxcoupe
13
Nov 20, 2015 08:43 PM
nabozny21
Oct 17, 2015 07:47 PM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
spooneralmighty
Sep 11, 2015 02:28 PM
