KR increases as I decrease the timing tables
#21
Dr. X, increase that KR recovery rate. Change it to 0.2, it will look a lot better on your scan that way, easier to read too. How are your BEN's 1.0 when you are 4 tenths away from your commanded AFR? Your actual vs. commanded seems to be kind of all over the place in that scan.
Get rid of that metric junk....
I like to leave my VSS metric and change the name to "MPH", looks like Im flyin!
#22
The best option is to just avoid the lugging in the first place via trans tuning.
#24
I have the knock problem also at 2000-2400 rpm in 4th locked, lugging but not the lean condition. I never could tune it out, so I just left it, added a little timing so it was where I wanted it with 1-2* of knock.
#26
Here's the new unfiltered BEN Map(should have left the idle portion of the VE table alone). No more lean cells 1800-2000 RPM.
But there is still KR here even when rich with pretty low timing and under steady state conditions. So that even rules out the .2-.4 sec lag between commanded and WB AFR as being an issue.
I don't think running off the MAF would help this. Probably best to just avoid boost in 4th gear(low RPM)/high load situations. Too much air with nowhere for it to go, resulting in excessive cylinder pressures/temperatures or whatever for street gas. 4th is for cruising, boost is not. Might be better off with no boost and more timing in 4th.
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
Boombastic
Aug 5, 2015 11:38 AM
