knock retard
Old May 28, 2013 | 04:10 AM
subeone's Avatar
Default knock retard
Have any of you guys had problems with KR with a cammed, fbo truck?
Was looking at a truck that had KR everywhere on a stock timing table. I checked for any rattling of the exhaust but no dice, is it notorious for trucks to pull timing when a noisy am is installed? Never seen anything like it...
Old May 28, 2013 | 04:14 AM
ak2007r6's Avatar
Post a log, tune. What motor? More details..
Old May 28, 2013 | 09:41 AM
nonnieselman's Avatar
Pretty much summed it up.
I desensitized my Knock sensors after i put the cam in mine.
Old May 28, 2013 | 09:47 AM
GMCtrk's Avatar
It needs to be fully investigated, but false knock is a bitch.
Old May 28, 2013 | 10:09 AM
Ferocity02's Avatar
Mine false knocked with just a cam/spring swap with the stock timing table. I pulled 5-10 deg of timing from the problem areas, and went from 87 to 91 octane and it still did it. Didn't make the pinging sound either so I was pretty certain it was false. It was only in the 1500-2000 RPM range at low-mid TP.
Old May 28, 2013 | 10:14 AM
If its a 1999-2001ish then upgrading to the 2002 OS will help. 12212156 is the OS your looking for.
Old May 28, 2013 | 11:54 AM
subeone's Avatar
So you guys do reduce the sensitivity. I worked on two heavy cammed trucks and they were getting ridiculous KR on the stock timing. What timin do you guys usually run on say a 228/228 112 lsa lq4? I was commanding around 24 degrees WOT and i was getting knock, so i brought it down to like 10 and it still registers as knock.
My stuff was stolen but i managed to get a log i had saved and the file
File Type: hpt
File Type: hpl
Old May 28, 2013 | 12:29 PM
what year are they? I dont have HPT to check them.
It could possibly be bad knock sensors also.
Old May 28, 2013 | 12:46 PM
subeone's Avatar
It is an 04 lq4, you think running little timing might cause knock
Old May 28, 2013 | 12:50 PM
Ive never seen that before.
My Tahoe pulls alot of timing but it has a couple codes set for the knock sensors. So i gott get to changing them.
