Knock retard
Old Sep 16, 2006 | 02:03 PM
fredokc's Avatar
Default Knock retard
i need a little help guys. I am getting knock only in overdrive around 42 mph. I dont get any at full throttle or part throttle. Only when I am cruising around 42 mph. Any addvise would be great. I am tuning with hpt.
Old Sep 17, 2006 | 02:15 AM
James B.'s Avatar
That is a little bit bizzare. I would start looking for something rattling or resonating. To be confined to such a specific condition like that is what makes it strange. Even if timing were advanced so much that was the cause of the KR, it should not matter what gear you are in or how fast you are going, it's a function of load (MAP) and RPM, and to some extent Throttle position so "closed throttle" or "open throttle" table is referenced.
Is there something else happening at 42mph? Maybe the torque converter is locking up perhaps?
If you have the ability to log data, find out what MAP and RPM it is happening at and try to reproduce it in third or second, perhaps with the parking brake engaged for just a moment to recreate the right amount of load.
Old Sep 17, 2006 | 12:00 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
In OD, TC locked you're lugging the engine. I had a similar issue. Moved TC lock up to 55mph, and had it tuned out on the dyno.
Old Sep 18, 2006 | 06:50 AM
dewmanshu's Avatar
Moderately Differentiated
have you tuned your ve table? the lower rpm/higher map areas... when you go into overdirve and give her a little gas, as mentioned above lugging occurs, but it hasn't kicked in pe yet nor should it probably. maybe some tweaking in the lower rpm/higher map areas or just a simle lock up speed adjustment as trever has eluded to. check all things jims mentioned as well. since you are tuning with hpt, give us some insight on the things you have changed already or post up your tune and/or scans.
Old Sep 21, 2006 | 06:37 PM
fredokc's Avatar
Thanks for the help guys. I moved the torque converter up to 50 and the knock is gone. I am going to try this and see how it goes.
Pimpinpete
43
Dec 22, 2017 08:13 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
trevorh1
Sep 27, 2015 08:47 PM
ZxHybrid
Sep 18, 2015 04:44 PM
Pimpinpete
Sep 8, 2015 07:39 PM
