knock, knock...
Old Jul 30, 2007 | 01:40 PM
Country Boy's Avatar
Senior Member
Default knock, knock...
I have one strange issue. When I hit the gas, I automatically get 8*s knock straight across the board. Also, my timing disappears to 0 or negitives. It just started this. Also,IMHO, it looks like the MAP hit 100 kpa very fast and sometimes at ~30% throttle. It doesnt seem right to me. I did throw a knock sensor code for low signal or something so is this its failsafe?
2004 GMC 5.3 truck. Only mod is a catback.
Both log and tune in link: http://www.hptuners.com/forum/showthread.php?t=13533
Old Jul 30, 2007 | 02:01 PM
Grumpy5.3's Avatar
Bet you money if you pull the intake off and look at the rear knock sensor, it will be rusty and corroded. There is a bulletin about replacing them and building a damn of silicone about 80% of the way around the hole for the knock sensor leaving the open part in the rear..
Old Jul 30, 2007 | 02:06 PM
Rhino79's Avatar
9 Second Club
Yep, I had a buddy with an F-body we were tuning on and his threw a knock sensor code and instantly went to 0* timing and of course KR was maxed at 8*.
Old Jul 30, 2007 | 02:40 PM
Senior Member
Looks like a plan tomorrow if I can find out for sure if the F body knock sensors are the same...
Old Jul 30, 2007 | 06:38 PM
Stoichiometric's Avatar
If you have a knock sensor code you are running exclusively on the low octane spark table. Is the knock audible or does it only show up in the scans?
Old Jul 30, 2007 | 06:54 PM
Change your knock sensor. I have ran into a few of these.
Old Jul 31, 2007 | 06:47 AM
Senior Member
no audible knock. It only started KR after the sensor code. Im changing them today and Ill report back.
Pimpinpete
43
Dec 22, 2017 08:13 AM
trevorh1
Sep 27, 2015 08:47 PM
ZxHybrid
Sep 18, 2015 04:44 PM
dantheman1540
Sep 15, 2015 08:28 PM
Pimpinpete
Sep 8, 2015 07:39 PM
