KBRacing Style Turbo Tuning
Old Jul 31, 2011 | 10:54 AM
bullygoat's Avatar
Default KBRacing Style Turbo Tuning
I'm trying to decided between a maggie and a log style turbo setup. The hangup I'm having now is, how are you guys tuning you're turbo setups? I see how the drivers side O2 will still read correctly but the passenger side has a mix of the drivers and passenger side exhaust so that could throw off closed loop fueling. I don't want to run an open loop tune because here in the north east, we can get a 30 degree temp swing from morning to late afternoon. Hopefully I've made myself clear enough.
Old Jul 31, 2011 | 12:10 PM
scooter k's Avatar
Subscribed
Old Jul 31, 2011 | 12:20 PM
Doc_speeder's Avatar
^^^^^yup^^^^^
Old Jul 31, 2011 | 12:27 PM
joeyc125's Avatar
11 Second Truck Club
It works out just fine, unless you have other problems, if you watch your fuel trims from bank to bank, they should very close to each other at all times. I have never seen an issue whatsoever with the way its setup.
Old Jul 31, 2011 | 12:49 PM
bullygoat's Avatar
It's when a problem may arise that I was concerned about. I'll have to look into HPTuners more and see if there is a way to keep the fuel trims equal.
Old Jul 31, 2011 | 11:58 PM
02'Z71ONDUBZ''s Avatar
Almost all front mount's are set up this way. I was a bit skeptical also, but the fuel trims will act surprisingly well. You wont have any issues running in closed loop.
Old Aug 1, 2011 | 12:08 AM
smokeshow's Avatar
Mod with training wheels
It really isn't a problem. Its surprising how well the O2s switch. You can tell its off, but its nothing that will throw off your tuning. Thumbs up for Kyle's kits
Old Aug 1, 2011 | 01:39 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
When you're tuning, and making adjustments to fueling, you are not adjusting bank 1 seperately from bank 2. You're doing all of it together. The only drawback of the configuration would be trying to use the O2 readings for troubleshooting driveability issues. Otherwise it will work just fine.
Besides, Maggie trucks are slow.
Old Aug 1, 2011 | 09:22 AM
slowec's Avatar
Old Aug 1, 2011 | 10:58 AM
03sierraslt's Avatar
A correctly setup open loop tune wont have much of a issue with temp changes. I run mine in bigger temp swings then that and all is fine.
