Idle Tuning
Old Dec 26, 2009 | 10:09 PM
MikeGyver's Avatar
Default Idle Tuning
I thought you fellers would like to see what I've been up against trying to get my truck to idle. I put these injectors in two years ago with my new engine, and I've always thought all of my idle problems were due to my cam, even though the cam was supposed to idle almost as good as stock. I found one exhaust valve chocolate-brown colored, the rest were white. I decided to get the injectors cleaned and tested while the engine was apart, and this is the test result:
Old Dec 26, 2009 | 10:39 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
that's interesting! Good find.
Old Dec 26, 2009 | 10:52 PM
GMCtrk's Avatar
well, which injectors are they?
Old Dec 26, 2009 | 11:19 PM
MikeGyver's Avatar
Siemens 60 lb'ers. I don't know the part number.
Old Dec 27, 2009 | 12:00 AM
viciousknid's Avatar
Where's the Beef?
What do you use to check each injector individually?
Old Dec 27, 2009 | 12:09 AM
Wheatley's Avatar
Truck Sponsor
Seen this alot.getting them flow matched is the best thing to do IMO.
Old Dec 27, 2009 | 12:29 AM
MikeGyver's Avatar
money. you send them to a clean and test service. i used cruizin performance.
Old Dec 27, 2009 | 08:12 AM
hirdlej's Avatar
Was it very expensive? I was thinking of sending mine in before I take my truck out this spring...
Old Dec 27, 2009 | 09:59 AM
03sierraslt's Avatar
I have the same injectors, only I got a flow matched set. I had a hell of time tuning mine till I got some good #'s for them. What cam are you running Mike?
Old Dec 27, 2009 | 01:50 PM
MikeGyver's Avatar
These are a "flow matched set", too. In my case, I guess flow matched means that the reseller usually gets lucky when they grab eight out of the bin.
My cam's specs include these numbers: 222, 224, .566, .568, and 115 LSA.
noproblems209
Aug 10, 2015 06:57 PM
Suburbazine
Aug 9, 2015 01:17 AM
fillpot
Jul 26, 2015 07:21 PM
GMCtrk
Jul 17, 2015 06:39 PM
GreyChevy
Jul 7, 2015 08:57 PM
