idle problem in my 92 tbi 350
Old Mar 3, 2012 | 05:21 PM
matt92extcab's Avatar
Default idle problem in my 92 tbi 350
My truck runs great at start up and warmed up but after driving for about a hour it starts to idle ruff like almost misfiring any idea what the problem could be
Old Mar 3, 2012 | 05:27 PM
1994Vmax's Avatar
Check engine light ever come on? With that explanation it could be almost anything.
EGR valve could be sticking open which of course causes a terrible idle but is not noticable otherwise.
I mean it could be the distributor too, pickup module, cracked reluctor wheel on the shaft ( pop the cap and take a look at the wheel that triggers the module) etc.
Old Mar 3, 2012 | 05:30 PM
No check engine light it just started doing that
Old Mar 3, 2012 | 05:38 PM
1994Vmax's Avatar
Or fuel pressure, coolant temp sensor going stupid, bad engine ground, you name it. Start checking away and see what you find.
Old Mar 3, 2012 | 06:10 PM
Ok thanks
Old Mar 3, 2012 | 07:12 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is this truck stock, or modded? Post up your mod list if it is.
Old Mar 3, 2012 | 09:49 PM
Flowmasters, stage 1 chip that's it
Old Mar 3, 2012 | 11:18 PM
ECT sensors fail frequently & make the run extremely rich. Happens without setting any codes. But it's easy to verify with a scantool, just look at the ECT sensor reading, and see if it's correct. If the sensor is telling the PCM that it's -40*F, it's gonna run like ****.
Another big cause of a rough running truck would be a worn out cap & rotor, and spark plugs. They should be replaced every 30K miles, and seem to get ignored all the time. Also, look for a bad coil wire, or a corroded post on the coil tower. Also check the reluctor on the distributor shaft for cracks, and see if it's loose on the distributor shaft. Lastly, check and set the ignition timing, and take a look at the fuel injector spray pattern.
That covers about 90% of what goes wrong.
Old Mar 4, 2012 | 12:41 AM
Thanks ak I changed the plugs and wires like 1000 miles ago but not the cap and rotor im gonna try there first
simman22
Jan 21, 2017 10:27 PM
Brandonlflr12
Sep 9, 2015 03:54 PM
Pimpinpete
Sep 8, 2015 07:39 PM
custm2500
Sep 8, 2015 05:53 PM
mayko
Sep 7, 2015 12:24 PM
