Idle misfire - cant figure it out
Old 05-14-2007, 09:05 AM
86MC_SS's Avatar
Default Idle misfire - cant figure it out
have an annoying misfire at idle. I did plugs and wires and it helped nothing. I tried doing a case learn and for some reason the VCM scanner would not allow me to do it. I followed the directions but the case learn button would not highlight to allow me the option to try the feature out.
What else can I try to get rid of this annoying misfire at idle? Here is my tune and a log at idle. I scanned each cylinder for misfires and misfire history.
02 silverado 4x4 5.3
mods: Comp Cam XR265HR 212/218, .522/.529, 114LSA, Pacesetter LT's & ORY, Intake, Gibson catback, 35" tires, 4.10 gears, stock 1800 stall
thanks in advance.
File Type: hpl
Old 05-14-2007, 12:17 PM
Hello Dave
dc_justin's Avatar
What rpm do you idle at? I can't view your log, but do the misfires show up within? If so, can you correlate them to your air/fuel ratio?
Old 05-14-2007, 12:32 PM
86MC_SS's Avatar
idle at 700rpm
the log shows the misfire.
air fuel should be fine. i have leaned it out and richened it up to see if anything helps and nothing does.
Old 05-14-2007, 12:33 PM
Hello Dave
dc_justin's Avatar
Originally Posted by 86MC_SS
idle at 700rpm
What's your idle timing like? Are the misfires localized to a specific cylinder, or do they occur randomly?
Thanks,
Justin
Old 05-14-2007, 12:41 PM
86MC_SS's Avatar
Idk if this will help...
idle timing is showing between 15-16 (hit 20 on one cell). I revved the truck up really quick just to show the misfires.
Old 05-14-2007, 12:48 PM
Hello Dave
dc_justin's Avatar
Your long term trims are rather high. If they're being caused by a leak of some sort, then that could be causing an intermittent lean misfire, especially with a cam. Can you step through a log and look at your O2 sensor voltages at exactly the point that a misfire occurs and check them out? Even in closed loop, the switching action of the O2 sensors can trigger a lean misfire here and there.
Old 05-15-2007, 04:05 PM
86MC_SS's Avatar
I raised my idle timing to 35* and the truck has a noticeably better idle.
I was also told that my idle fuel trims need to be tweaked. I dont know which tables to tweak though
Old 05-15-2007, 04:13 PM
Hello Dave
dc_justin's Avatar
Fuel trims are a learned value based on the "error" between the PCMs calculation of required fuel for a given operating condition and actual. If your trims are positive (which they are), then the PCM is undercalculating the amount of fuel needed. This calculation is based on MAF, VE, IAT, ECT and IFR primarily. Airflow/airmass calculations made from MAF, VE, IAT, ECT are then used to calculate needed fuel flow based on commanded AFR and the injector flow rate.
If you're seeing a lot of reversion due to that cam, could be causing some of your idle fueling issues.
Best bet is to get your VE table nailed down via some method (wideband is preferred), then nail down your MAF calibration as needed.
86MC_SS's Avatar
also checked for leaks last night. spent about an hour looking. did all my old carb tricks to find one and nothing.
cousblake11
09-09-2015 06:52 PM
MA$TER_E
09-09-2015 03:14 PM
CammedZ71
11
09-09-2015 02:05 PM
Pimpinpete
09-08-2015 07:39 PM
custm2500
09-08-2015 05:53 PM
Quick Reply: Idle misfire - cant figure it out
