IAT removal without going SD
Old Apr 24, 2006 | 10:07 AM
Yelo's Avatar
Default IAT removal without going SD
Is there a way to remove the IAT from the PCM calculations without going 100% speed density ??, I ask because I'm seeing wierd performance issues that I'm pretty certain are PCM related. If I run in SD mode the current problems go away but a whole new set is created due to the 1/2 resolution VE tables in the '99 PCM's (I'll upgrade eventually but not right now). I'd like to be able to bias the fuel/spark equations towards the ECT (engine coolant temp) like SD mode does instead of the IAT. Is this possible ??
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
