hypertech help
Old May 27, 2007 | 09:03 PM
ramsey rider's Avatar
Default hypertech help
i installed the hyp before i ever joined this forum.i went to uninstall it and for some reason it says youre battery voltage is to low please try again after you fix problem:i cant even get into it past turn key to run position,any solutions:i cant even uninstall it.
Old May 27, 2007 | 09:08 PM
silent1's Avatar
Connect a charger and/or make sure all lights and accersories are off.
Old May 27, 2007 | 10:07 PM
do you think having 2 batteries would do this i put in a 2nd batt formy plow?
Old May 29, 2007 | 09:08 AM
ChevyThunder17's Avatar
If one battery was really low, it'll be a load on the other one. Hook up a charger for now as recommended to get the tune undone, and have both batteries checked.
Old May 29, 2007 | 06:38 PM
suzukibruce's Avatar
DO NOT DOWNLOAD WITH CHARGER HOOKED UP!!!! you may burn out your programmer and your ecm.... charge the batteries first then dl
Old May 30, 2007 | 01:17 AM
With HP Tuners, you could get away with a trickle charge on the batteries, but then again you are using a laptop with it's own power source.
BIGD4504
Jul 28, 2015 11:46 AM
work in progress
Aug 29, 2002 11:36 AM
CashDudeHomie
Jul 13, 2002 06:23 PM
