HUGE voltage drop issue....SOLVED?
Old Mar 30, 2009 | 06:28 PM
KySilverado's Avatar
Wow this is like the 3rd thread of "I found it" the boy crying wolf story comes to mind.
Anyway did I see a request for pinout of the obdII port?
Old Mar 30, 2009 | 06:31 PM
foff667's Avatar
LS1TECH Sponsor
Glad to hear you found the issue, I was truely baffled on this one as was our hardware designer as neither of us had ever run into such an instance.
Talk about a needle in a haystack though it definitely would've had me at this point
I figured it was something in the obd2 port or wiring thereafter but I guess I'll keep our pins in mind next time as well, I guess you keep the obd2 cable connected to the obd2 port at all times & just plug in the interface when needed?
-Bill
Old Mar 30, 2009 | 10:34 PM
dewmanshu's Avatar
Moderately Differentiated
-Bill
Yeah, IF I was to ever take it to a dealer (which i need to for some recall stuff before they go bankrupt) I just take it out. But not anymore, I remove it now. LOL
Yeah cry wolf.......and yes...I am doing a call out for the OBD II wiring diagram. I guess I should use the search button and find my own damn threads huh?
https://www.performancetrucks.net/fo...d.php?t=373444
foff, can you tell me which pin on the OBD2 that damaged pin goes to? I'll continuity them out, but just curious if you had that info handy.
I would just like to see the wiring diagram for those pins.
Old Mar 31, 2009 | 11:00 AM
budhayes3's Avatar
PT's Slowest Truck
Wow, that's pretty cool, seems so simple yet so hard to track down (as many electrical problems usually are). Seems like you have it "pinned" down now, pun intended
Old Mar 31, 2009 | 11:24 AM
dewmanshu's Avatar
Old Mar 31, 2009 | 12:16 PM
Wilde Racing's Avatar
How do I change this text
so did wilde really tell you dewster????????
Hell no, I told him to burn the truck and start over.....
Old Mar 31, 2009 | 06:51 PM
XLR8NSS's Avatar
Adkoonerstrator
I told him the SAME thing!!!
Old Mar 31, 2009 | 07:05 PM
Gordy M's Avatar
I would just like to see the wiring diagram for those pins.[/QUOTE]
I found this in my archives, HTH
File Type: doc
Old Mar 31, 2009 | 07:12 PM
Well to answer your question. 4 and 5 are both grounds on different circuits.
Pin/Circuit #/Name
1 -- -- Not Used
2 PPL 1132 DLC Class 2 Serial Data
3 -- -- Not Used
4 BLK 1850 Ground
5 BLK/WHT 451 Ground
6-15 -- -- Not Used
16 ORN 640 Battery Positive Voltage
Attached Thumbnails HUGE voltage drop issue....SOLVED?-tiftogif.gif   HUGE voltage drop issue....SOLVED?-tiftogif1.gif   HUGE voltage drop issue....SOLVED?-tiftogif2.gif
Old Mar 31, 2009 | 07:59 PM
bigbadwolf54's Avatar
13 Second Truck Club
Pin/Circuit #/Name
1 -- -- Not Used
3 -- -- Not Used
4 BLK 1850 Ground
6-15 -- -- Not Used
FYI
ckt 451 ends at G103, located at the right rear of the engine block, it has been known to have the wiring break inside the insulation at this location and cause some weird electrical issues
ckt1850 ends at G203 which is located at the drivers side a-pillar, behind the dash pad near the base of the windshield
