HPTuners NNBS tire change=brake and ABS light
Old May 23, 2017 | 03:04 PM
  #21
TXsilverado's Avatar
ehh, it doesn't really matter. most tuners I know of do tuning as a side business, not a full time income.
Old May 23, 2017 | 09:26 PM
  #22
mcfarlnd's Avatar
Un-Registered User
Originally Posted by 2xLS1
Because I've changed tire sizes on hundreds of NNBS trucks. I do this professionally FWIW. And unless you are trying to put in a 35" tall tire size I don't have this problem. I can fix his problem. Sorry he can't provide me with the information I need. And there is no need to use a HPT beta version on a 07 NNBS truck. There is nothing he can do with that beta version on that model truck that I can't do with V2.24. Perhaps it is a bug that is causing that problem with a 31.5" tire.
I use BETA to program the FSCM and a few other things. Shouldn't have to go into details about that because you "tune" professionally. As for the suggested "bug", that is one of the reasons I am asking "Who is having this problem"? I have been in contact with support trying to get to the bottom of it to get the bug fixed for everyone, if there is. Not stick with old software and let everyone else figure it out. It is called "giving back" to a forum that provides a lot of info to us. And "ridiculed"? Not entertaining that.....
Old May 23, 2017 | 09:30 PM
  #23
mcfarlnd's Avatar
Un-Registered User
why are you even posting? I just read like five of the most useless posts from you.. Im sure the op appreciates your help
Op, what tire size is in the tune currently?
30.79
Old May 23, 2017 | 09:41 PM
  #24
mcfarlnd's Avatar
Un-Registered User
Originally Posted by FFDP
Post the tune?
Contact support?
Added tunes
File Type: hpt
Old May 26, 2017 | 08:02 AM
  #25
Choda's Avatar
2xls1 is being a douche, ignore him.
Old Jun 1, 2017 | 01:28 PM
  #26
adunphy's Avatar
@mcfarlnd,
Sent you a PM. If that works out for you we can share it up here for others to use. Just didnt want to add to the confusion by sharing up some lightly tested method. :-)
Old Jun 5, 2017 | 09:07 AM
  #27
mcfarlnd's Avatar
Un-Registered User
Originally Posted by adunphy
@mcfarlnd,
Never got a PM. Sent you a PM.
Old Jun 11, 2017 | 07:24 AM
  #28
adunphy's Avatar
@mcfarland,
Glad the calcs in this worksheet worked for you. I can't explain why the HPTuners wizard does not work, I just know I've read posts over on their forum and done lots of testing/validation that the wizard does not work on truck E38 speed calcs. I believe they mention that if they "fix" the wizard for one group of E38 OS's, it breaks for the others. Apparently GM has changed the way they calculate speed a half dozen or so times throughout the E38 timeframe.
For others who may find it useful, I've attached the sheet below. Its pretty self explanatory and basically all it does is tries to keep the up/down scaling such that the front tires (non-driven) in the ABS module in sync with the rears so that the EBCM doesn't freak out and throw a code (C0245 with brake light + ABS light). The nice thing about the sheet is you can run different size fronts than rears and it will weight the PCM 128K signal accordingly.
The latest version of HPTuners, 3.6.x has added parameters to the tune; Driven wheel circumference and non-driven wheel circumference. I have played around with these PIDs to no avail and cannot explain how they play into the speed calc algorithm so I find it best to just leave those stock no matter what. If I figure out what they are doing I'll update my workbook and post here but for now this seems to work just fine without it.
Note: Please keep in mind that since you are adjusting these settings manually, you'll need to adjust your trans settings manually as well. You may be able to use the wizard for that or you could use the BlueCat BC_Trans tools which is a really nice free tool.
File Type: xls
Old Jun 23, 2017 | 08:31 PM
  #29
Truckshop's Avatar
After using the gear/tire wizard set the tcm values back to what they were stock. Your abs and brake light will stay off
Old Jun 30, 2017 | 08:17 AM
  #30
mcfarlnd's Avatar
Un-Registered User
What do you mean by TCM values? Shift speeds, RPM, TC lock up etc.?
