HPT & A/F guage?
Cart - SummitRacing.com
Or what all do you need to run HPTUNERS and a wideband. Thanks for the help.
The HPT MIV Pro has a connector socket on the side and comes with a connector. You take a wire from your WBO2 gauge (usually white) connect it to the correct pin (which is given by HPT documentation) on the connector then plug it into the MIV. You will need to set up a custom PID in your scanner to make use of the WB but its actually not that complicated. If you're going with a common WBO2, there will probably already be a PID available in the menu.
