HP Tuners!!! PLEASE COME IN
Old Jun 29, 2007 | 11:21 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by bgray
THat is the current tune....yes it is XTR if i remeber correctly
the problem is that my tuner is new with trucks, expert with vette/fodie...and my truck is running really slow. For the amount of mods
My mods are in my sig, or I am June TOTM for FUlll list......
I wnated a custom one off tune, but if Nelson Perf thinks they cna rock out way more power then i'll spend it no problem
Give us a call and I'll go over the details.
thanks
allen
Old Jun 29, 2007 | 11:42 AM
bgray's Avatar
TOTM: June 2007
is there anyway we could do pm's..that long distance call from up here in Canada will rape me...
bgray's Avatar
TOTM: June 2007
by the way...yor efan harness kicks ***..
Old Jun 29, 2007 | 01:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
Speaking from our experiance....picking up the phone will get you where you need to be faster than PMs. Allot of sponsors are owner/operators and do not spend a ton of time on the web.
I would call if I were you.
Old Jun 29, 2007 | 02:10 PM
bgray's Avatar
TOTM: June 2007
why is 5800 a waste??
Old Jun 29, 2007 | 04:33 PM
Moddoo's Avatar
What I mean is that you could be shifting at a higher rpm.
You're power should hold to 6200 at least.
Old Jun 29, 2007 | 05:00 PM
Wheatley's Avatar
Truck Sponsor
With that cam and 918's you can and should be spinning it higher.I had that cam and was spinning to 6300-6400.Pulled all the way to the shift with no problem.You have a nice cam,I loved mine.
Old Jun 30, 2007 | 08:29 AM
bgray's Avatar
TOTM: June 2007
okay. My tuner said the some other tables like knock werent touched cause he wanted to play it safe for blowing etc. IS there room to move on thsoe still? Like hes a good tuner, not denying that, made over 900hp on a stock ls6 block as a daily driver...
What is PE Delay?
How much of burst knock can you pull before it gets squirlley?
what is iat vs timing??
Were gonna log it and do some runs...see what he cna do...if its still not performing then i will take the enxt step.
I lvoe the cam, so i guess will take it to 6100 then log, and bump it agian..make sure the pwoers still there.
Old Jun 30, 2007 | 09:22 AM
Moddoo's Avatar
Do you have 32# injectors like the sig says?
A tune for 28# injectors with 32# injectors installed will destroy your performance.
This should be your first priority.
Old Jun 30, 2007 | 09:53 AM
bgray's Avatar
TOTM: June 2007
yah i do ahve the 8.1L ones....well have to change that...whats your thoughts on teh other stuff...if you dont mind me asking..im jsut extrememly newbie about this stuff
