HP Tuners error message
I put my truck in SD, and after driving around with the LT's learning, I go to "copy/paste" my LT's into my ve table, and I get an error saying
"An unhandled exception has occurred in your application"
Something about "Just-in-time" debugging
Anybody know anything about this?See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: QueryInterface for interface IOleDataObject failed.
at System.Windows.Forms.UnsafeNativeMethods.OleGetCli pboard(IOleDataObject& data)
at System.Windows.Forms.Clipboard.GetDataObject()
at j.(Object A_0, EventArgs A_1)
at System.Windows.Forms.ContextMenu.OnPopup(EventArgs e)
at System.Windows.Forms.ContextMenu.Show(Control control, Point pos)
at System.Windows.Forms.Control.WmContextMenu(Message & m)
at System.Windows.Forms.Control.WndProc(Message& m)
at C1.Win.C1FlexGrid.Util.BaseControls.ScrollableCont rol.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
VCM Editor
Assembly Version: 2.1.18.0
Win32 Version: 2.1.18.0
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/VCM%20Editor.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
C1.Win.C1FlexGrid
Assembly Version: 2.5.20053.220
Win32 Version: 2.5.20053.224
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1FlexGrid.DLL
C1.Common
Assembly Version: 1.0.20031.116
Win32 Version: 1.0.20042.118
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Common.DLL
C1.Win.C1Chart3D
Assembly Version: 1.0.20053.15236
Win32 Version: 1.0.20053.15236
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart3D.DLL
C1.Win.C1Chart
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
mscorlib
VCM Editor
System
System.Drawing
System.Xml
C1.Win.C1FlexGrid
C1.Common
C1.Win.C1Chart3D
C1.Win.C1Chart
enabled.
For example:
<configuration>
</configuration>
