hp tuners "engine type" questions...
Old Jan 16, 2006 | 06:31 PM
5.3 racer's Avatar
Default hp tuners "engine type" questions...
my pcm was originally for a 5.3, should i change the engine type to a 6.0 or doesn't it matter? i have slowly been getting the ve table inline and am now calibrating the maf sensor. thanks.
Old Jan 16, 2006 | 06:40 PM
chrisj6's Avatar
yes change the engine type to a 6.0, and if you havent already, you will need to adjust the displacement above it. The PCM uses this for fueling and other calculations.
Chris
Old Jan 16, 2006 | 07:41 PM
5.3 racer's Avatar
could you be more specific: "fueling and other calculations"? thanks.
Old Jan 16, 2006 | 09:24 PM
chrisj6's Avatar
I'm not sure exactly, i do know it uses the cylinder volume to help scale some of the tables in the pcm.
Chris
Old Jan 21, 2006 | 03:36 PM
Yelo's Avatar
I would think your AFR would be calculated incorrectly as well as IFR and PE if the displacement didn't match the actual engine
mr03silverado
Jun 26, 2016 06:05 AM
shawn96gmc
May 17, 2016 04:15 PM
BerryWS6
Jul 19, 2015 06:03 PM
hackrst
Jul 11, 2015 11:17 AM
