HP Tuners 3.0 scanner question.
Old Feb 13, 2016 | 11:44 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Default HP Tuners 3.0 scanner question.
I'm having trouble creating an AFR error channel. It looks very easy when I try it but my AFR sensor is pink in the "Math" parameter like I don't have it. I am successfully logging AFR from my AEM wideband I just can't get the error to log against the commanded AFR. Anyone have any suggestions off the top of your head?
Old Feb 14, 2016 | 05:04 AM
chris99gmc's Avatar
It's funny you posted this, Bc I'm having the same exact issue since going to 3.0... I just logged on to ask the same thing.
I'm using Lc1 wideband, but makes no difference there. Somebody please chime in and help us out. I feel like I'm just missing something simple.
Old Feb 14, 2016 | 07:30 AM
George C....'s Avatar
Formerly ScreamingL
Look under mvpi inputs...its what i did for my autometer
Old Feb 14, 2016 | 07:31 AM
03sierraslt's Avatar
Log your wideband input, log AFR Commanded HI RES, and log EFR ERROR %
Those are required to set up a afr error table
Works just fine, I used it yesterday.
Old Mar 2, 2016 | 07:19 PM
LIL6BT's Avatar
In 3.0 Make sure you have your wideband and AFR Commanded Hi Res in your channels. No need to add "Maths" to your Channels.
After that you would create a graph with AFR Error as the parameter. You will pick that parameter from the "Maths" section in the drop down menu.
Old Mar 2, 2016 | 11:14 PM
I forgot I posted this here. I got some help on hp tuners website.
What ^^ he says sums it up pretty well. To add to it, if you want to log actual AFR in your graph you would choose your LC1 from the transforms section in the drop down menu. Then when it asks you if you want to use the generic sensor then you would pick yes. The reason is you transformed your LC1 in the channel into the generic sensor for AFR.
6.Slow06
Apr 6, 2020 07:55 PM
03sierraslt
Mar 17, 2016 06:01 PM
ALL ULL C
Feb 16, 2016 09:51 AM
chopperloco
Feb 14, 2016 03:39 PM
!Hostile!
Feb 11, 2016 08:26 PM
