How are you guys passing an inpection?
Old 07-03-2011, 01:23 PM
  #21
Gadgetized's Avatar
There are 4 lights flashing. The guy that is doing my inspection said it won't pass with more than one of these flashing. Obviously the 4 lights that are not lit in the first pic are the ones that are not flashing.
Old 07-03-2011, 01:41 PM
  #22
terravast4's Avatar
I am running high flow cats and am not throwing any codes. my set up is 100% legal
Old 07-03-2011, 01:43 PM
  #23
terravast4's Avatar
I am running a SD tune if that makes any difference
Old 07-03-2011, 01:48 PM
  #24
terravast4's Avatar
Originally Posted by Gadgetized
Terravast4, How are you able to pass to drive your vehicle? I just want to be able to drive this legally, I dont care how I get a sticker on it. I am going to try everything like Scott posted.
I had to prostitute my little sister in Mexico to get a sticker.
Old 07-03-2011, 01:51 PM
  #25
Gadgetized's Avatar
lol Figures I don't have a sister.
Old 07-03-2011, 02:26 PM
  #26
FormerVendor
CalEditor@PCMCalibrators's Avatar
LOL
I don't think so.
Old 07-03-2011, 02:33 PM
  #27
Destroyer of Transmissions
1SlowHoe's Avatar
What about O2 sims? Then you can leave the report SES enabled but it wont set because the PCM is seeing the correct voltage. That's one blinking light gone.
Old 07-03-2011, 03:12 PM
  #28
FormerVendor
When I set up the off road PCM's the IM status for all of the IM Test Show completed & passed test when the PCM is on the bench even before its on the car
Old 07-03-2011, 04:33 PM
  #29
bullygoat's Avatar
Originally Posted by GM eSi
System
DTCs Required to Set System Status to YES
Catalyst
DTC P0420 or P0430
EVAP
DTC P0442
DTC P0446
DTC P0451
DTC P0454
DTC P0455
DTC P0461
DTC P0464
Oxygen Sensor
DTC P0133 or P0153
DTC P0140 or P0160
DTC P1133 or P1153
DTC P1134 or P1154
DTC P2A01 or P2A04
Oxygen Sensor Heater
DTC P0053 or P0059
DTC P0054 or P0060
DTC P0135 or P0155
These are the codes that need to run and pass to get each of the individual monitors to run.
I setup a tune specific to let my truck pass inspection. My O2s are bad and I haven't worked in 10 months and its a second vehicle. By setting these codes to 3-No Error Reported and Uncheck the SES-Enable box, they instantly pass when the ignition is turned on. This is in HPTuners. I'm not sure how this is done in EFI-Live.
Old 07-03-2011, 05:16 PM
  #30
terravast4's Avatar
Do you run this tune for inspection only?
Quick Reply: How are you guys passing an inpection?
