How Do I Test My Throttle Position Sensor?
Old May 24, 2009 | 05:42 PM
therock's Avatar
Default How Do I Test My Throttle Position Sensor?
I want to confirm my TPS is OK on my 2005.
Also, is there a relearn procedure.
Old May 24, 2009 | 09:22 PM
Wilde Racing's Avatar
How do I change this text
do you have a scan tool to watch pids with?
Old May 24, 2009 | 09:23 PM
00ChevyScott's Avatar
Wearin' da big hat
If he doesn't he could monitor the TPS connector with a multimeter for the volatage to change in response to throttle change.
Old May 24, 2009 | 09:29 PM
I "think" there are two different circuits. one 0-5 and one 5-0... but yea, good point...
Old May 24, 2009 | 09:31 PM
Wearin' da big hat
Forgot its a DBW tb, it might be more compicated as there isn't exactly a TPS sensor per se.
Old May 25, 2009 | 04:50 AM
therock's Avatar
Thanks,
I have an old Diablo Predator that has a pretty good scanner, I'll look to see if it displays PID's. What does PID stand for?
She is not tossing codes but has a studder at take off occasionally, and only when kind of on the cold side.
The TPS is located on the gas pedal.
Old May 25, 2009 | 08:19 AM
Derek @ EDO's Avatar
FormerVendor
PID stands for Proportional, Integral, Derivative
P Proportional Band = 100/gain
I Integral = 1/reset (units of time)
D Derivative = rate = pre-act (units of time)
Just a formula
Old May 25, 2009 | 10:37 AM
Mort's Avatar
PID
PID = Parameter Identifier = A single unit of information that may be retrieved from the ECM/PCM.
Such as:
VSS = Vehicle Speed Sensor
TPS = Throttle Position Sensor
MAF = Mass Airflow Sensor
O2 = Narrow Band Oxygen Sensor
Old May 25, 2009 | 11:42 AM
therock's Avatar
Thanks,
I put my Diablo handheld in live diagnostics and do have a throttle angle readout.
With motor off and key in run position it's reading 15%. This normal? I also get a smooth progression if I slowly press the pedal.
Whatcha think?
Old May 25, 2009 | 12:01 PM
be sure the pid you are looking at is actual tps angle. There are a number of pids that have to do with tps, some will not read 0-100% but will start out at 15% or so and only go up to 80% or so...
