How do I lean out part throtle AFR?
Old Mar 16, 2008 | 08:20 PM
  #31
dewmanshu's Avatar
Moderately Differentiated
I recently increased my rpm delay. LOL I am getting more aggressive with the lean transition.
Old Mar 16, 2008 | 10:01 PM
  #32
Wilde Racing's Avatar
How do I change this text
I got you e-mail. I'll try and get back with you tomarrow....
Old Mar 27, 2008 | 02:28 AM
  #33
syclone0569's Avatar
Originally Posted by stock48
HA! I just disabled the MAF and went foe a drive. It idled wierd for a few seconds and smoothed out. Truck runs perfict. I wish I had read your recient post. I went 3/4 throttle a few times under boost while watching the AFR. I guess I got lucky, because AFR went to about 12.2-12.5. Driving under cruise conditions AFR is about 14.5-14.9, and under moderate accelleration AFR is 13.2-13.7. Light Acceleration AFR is 14.2 or so. Im happy with that. Now how do I get it to run that way with the MAF hooked up? After seeing how well it drives without it, I can see it needs to be gotten rid of. Thanks, J
WOAH!!!, so correct me if im wrong here, all you did was disconnect your maf, and the truck ran great?? "idled wierd for a few seconds and smoothed out"
"Driving under cruise conditions AFR is about 14.5-14.9, and under moderate accelleration AFR is 13.2-13.7. Light Acceleration AFR is 14.2 or so. Im happy with that."
damn right i would be happy with that........!!!!!!!!!!!!!!!!!!
my mileage would be where it should be then!!
how would this work on a mostly stock 5.3??
only mods are a 3.5 cat back,
and an k&n fipk???????????
Old Mar 28, 2008 | 03:00 PM
  #34
SS_bnoon_SS's Avatar
Just FYI, the IAT is in the MAF, so you for sure don't want to simply disconnect it and run it that way all of the time, especially on boosted applications. If you're going MAFless, you'll need to wire in a stand alone IAT/
Syclone, as for disconnecting the MAF on your truck, there's almost no way in heck it would work to simply disconnect the MAF without tuning the VE. He simply got lucky that he had the VE tuned close to what it needed to be to run those numbers. Who knows though, disconnect it and log what happens...
Old Mar 28, 2008 | 06:13 PM
  #35
Exclamation
i have ran all day today, with the maf disconnected,...i took a needle nose pliers and pulled the little iat out of my maf.
plugged that little iat back on, and laid it next to my k&n filter.
im after mileage, thats it.
before ltft were in the +8 to + 10%
before stft were in the +4 to + 6%
after ltft were the +0 to + 0%
after stft were in the -3 to - 10%
much betrer mileage from the big truck with 35" tires.
mz00516
Aug 23, 2015 12:19 PM
02singleturbo
19
Aug 20, 2015 05:55 PM
05GMC4.8
Aug 7, 2015 09:55 PM
zblee
Aug 3, 2015 03:45 AM
signguy62
Jul 16, 2015 05:43 PM
