How do I change this?
Old Oct 24, 2006 | 06:32 PM
12sec.5.3's Avatar
Default How do I change this?
When I crank up my truck the rpms go to about 1200 and come down very slow to my desired idle. It also does this when I rev it, comes down to about 1200 and goes down very slow until reaching my desired idle of 675. I would like it to be a "quick" rev and back to idle.
Old Oct 24, 2006 | 06:46 PM
nonnieselman's Avatar
do you have a 2002 PCM? My stock 2000PCM didnt do that, but now i have a 02 it does that.. it dont bother me at all..
Old Oct 24, 2006 | 07:40 PM
Flyer's Avatar
DId you work on the VE table? What about you ridle tables, how much did you raise them if any?
Old Oct 24, 2006 | 08:16 PM
12sec.5.3's Avatar
nonnie-Yes, it just started since I swapped to the 02 pcm.
Flyer-I had someone here help me with my tune so I'm not exactly sure what they've done. I know it helped a lot, but there are some things that still need to be adjusted.
Old Oct 24, 2006 | 10:45 PM
Kano's Avatar
your idle rpm table is ect based
as well as some of the idle airflow tables
Is it just when the engine is warming up?
Old Oct 25, 2006 | 12:35 AM
Wheatley's Avatar
Truck Sponsor
there are a few tables for that but if yuou have EFI live I can not help you that much
Old Oct 25, 2006 | 01:01 AM
dc_justin's Avatar
Hello Dave
Play with table B3407, your desired airflow table. Comparing your tune that you sent me to a stock LQ9, your desired airflow is about 15% higher from 80*C (176*F) and up. Try replacing the bottom 6 rows of 7.8 & 7.5 with 6.5 & 6.3.
Old Oct 25, 2006 | 01:59 AM
Tan327's Avatar
I don't know how crazy your cam is but try 6.5 & 6.3 like Justin said, if it has trouble idling just raise both up a little.
Old Oct 25, 2006 | 06:54 PM
12sec.5.3's Avatar
Ok. But wouldn't that cure it just when the engine is warm?
Old Oct 25, 2006 | 06:57 PM
dc_justin's Avatar
Hello Dave
Well that table deals with all engine temperature conditions. There are other conditions that can cause this issue as well.
To be honest, I would get your VE nailed down, then your MAF nailed down first, especially with your MAF de-screened. Get that wideband hooked up properly and go with it. Your idle issue might not be as pronounced at that point.
