High Beam Light On With Ignition On/Off
Old Apr 6, 2016 | 04:45 PM
KG7AMV's Avatar
Registered User
Default High Beam Light On With Ignition On/Off
My high beam light on the Cluster stays lit all the time even with the ignition off? After a few days dead or weak battery.
I pull the IPC/DIC fuse and it goes off bat is ok. No Other Fuse Affects it.
Thinking Instrument Cluster or BCM?
Replaced steppers few years back to die being erratic.?
Had a similar issue where the wiper controller kept all the ICP and Radio light on that was simple to fix replaced wiper controller.
Another issue I have is remote door locks hit unlock once it unlocks drivers door have to hit it 3/4 times to unlock all other doors (yep battery is good in fob). Reasoning for thinking maybe BCM? Any Ideas>
Rockgirl4life
Apr 1, 2016 12:25 AM
Kendall Campbell
Mar 31, 2016 04:25 PM
Suburban2500
Mar 26, 2016 09:33 PM
DopdBrd
Mar 19, 2016 04:35 PM
