Help! Passenger door has no power...
Old Mar 20, 2012 | 10:12 PM
JoeGibbSilverado's Avatar
Unhappy Help! Passenger door has no power...
Craziest thing I have ever seen...everything worked fine, and now nothing. The pass window wont roll down, using driver switch or pass switch, doors wont unlock using key fob...driverside door will unlock using the driverside switch, just not the passenger side, turn signal in pass mirror doesnt work either..... what gives???
Old Mar 20, 2012 | 11:58 PM
Suburbazine's Avatar
wiring harness in door hinge area is probably cut or yanked out. Pop up the armrest switch panel and test light the power wires on the plugs.
Does the door light (if equipped) work?
Check the fuses for the alarm system/body control module. Sounds like one may be blown as well. (Test light on both sides of fuse works better than visual verifications and is a lot faster)
Old Mar 21, 2012 | 07:39 AM
Door light doesn't work, but while taking out my cd player I noticed some wires from the alarm chimer came un hooked, maybe that's the problem
Old Mar 21, 2012 | 03:27 PM
I doubt it but good luck.
Old Mar 21, 2012 | 04:51 PM
You were right, dammit! lol. Didnt change a thing
Old Mar 21, 2012 | 05:19 PM
Also, If im sitting in the truck and push the lock button, of course only the driverside door locks, but the security light flashed in the cluster........
Old Mar 21, 2012 | 11:48 PM
Check fuse for the PDM located in the right side dash junction block.
rumblebox
Oct 29, 2015 10:35 AM
BCraven1018
Oct 1, 2015 08:22 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
madmann26
Sep 7, 2015 06:41 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
