Help! P0101, P0171, P0174
Old Nov 25, 2009 | 11:55 AM
Dirty 30's Avatar
LS1Tech Whore
Ok so i went and tested the fuel pressure on the return side. At idle the feed is 42-44 psi and return side is 6 psi. This tells me the pump is weak like u guys said. Im gonna replace it and hope it helps.
Old Dec 16, 2009 | 08:08 AM
dfoxy's Avatar
Registered User
Dirty 30: Did you R&R the fuel pump? If so, did that fix the problem? I have the exact same problem I've been chasing for a couple of weeks now, and don't want to just throw parts at it.
Thanks.
Old Jan 10, 2010 | 02:39 PM
williebones's Avatar
ive got this problem now too, would like to know if its the fuel pump also before i spend the $500.
Old Dec 12, 2010 | 02:04 PM
L.A04SS's Avatar
Registered User
Hey wasup im just got the same codes on my 2004 ss did changing the fuel pump fix the problem thanks
Old Dec 12, 2010 | 05:49 PM
bighoss77's Avatar
why would low fuel pressure be cuasing knock sensor codes to show up? j/w i also have been battling knock sensor codes, but i have yet to ohm out the sensors or check/add a block ground... guess i need to also check fuel pressure while im at it...
Cakes
Apr 23, 2010 07:30 PM
Blown06
Jun 22, 2009 03:10 AM
fastjweb
Nov 1, 2006 12:44 PM
gr8twhite
Jan 26, 2006 02:01 PM
