trouble code p0171 and p0174
Hey guys, my 05 silv 5.3 cc keeps popping up these codes p0171 bank 1 lean and p0174 bank 2 lean. I have superchips w/ 91 tune, headers, exhaust, tb spacer, slp 160, cold air intake, and mass sensor, and ported throttle body, and 4.10's. normally ill get the occasional p0102 when i have a intake leak, but never had these codes. Thought it might be because i changed the plugs, but they were stock replacement. Pulled the a couple plugs from each side and they looked like they were getting hot, pinkish. I have a set of 31lb injectors i could throw in, would this help, or are plugs the problem. seems sluggish of line, but picks up the same higher rpms. any help would be appreciated.
do check your fuel pressure though!
it can be an exhaust leak as well or clogged injectors ,O2 sensor failed
or something with the tune or possible MAF issue
i bet its the maf sensor, put a gms sensor on my cousins 05 5.3 and it was sluggish down low and couple days latter got the same codes put his factory maf back on and his low end picked back up and the codes haven't came back
thanks man, i had it on for almost 30,000 miles and now i am getting the codes, but would that make the plugs run lean though?, its not pinging, knocking nothing, just doesnt smoke em off the line anymore, when i got the 4.10's it will light up through second, hope thats the prob. thanks
