Help me get this 4.8L running!
Old Aug 13, 2013 | 04:19 PM
oakley6575's Avatar
Default Help me get this 4.8L running!
So the truck fires up every time no problem. It runs for a sec and then the idle desired airflow starts to skyrocket (.545 increasing to 4.5). Obviously the idle air trims go to 150+ when this happens and the rpm shoots up to 2500 or so then drops to 300-400 rpm and stumbles until it dies. I can't tell if the truck is rich or lean. The wideband will read for a sec and then it shows ---
I put a ls3 maf on this truck so I know it isn't tuned or it yet. When I try putting it in SD, it will fire and immediately die just like sprayedenali's truck was doing. Check out my normal tune and the SD tune and let me know what you see.
I copied a stock 4.8L MAF and VE table to these tunes so it shouldn't be too far off.
File Type: hpt
File Type: hpt
Old Aug 13, 2013 | 04:47 PM
smokeshow's Avatar
Mod with training wheels
Set 'High RPM Disable' in Dynamic Airflow to 12800. And set P0101-P0103 to 2 - No MIL light, SES unchecked.
Old Aug 13, 2013 | 05:14 PM
oakley6575's Avatar
Okay thanks Jake. That kept it running in SD. So now the problem is it just falls on its face after initial start up. So it will start and go almost immediately down to 400-500rpm and hang there till it dies or I shut it off. You can see the idle desired airflow is F'ed.
File Type: cfg
Old Aug 13, 2013 | 05:33 PM
oakley6575's Avatar
Got it. Runs like a Cadillac!
Old Aug 13, 2013 | 05:47 PM
smokeshow's Avatar
Sweet
Old Aug 14, 2013 | 04:46 PM
oakley6575's Avatar
Another question. My VE table seem abnormally high. It is wanting 120+ numbers under WOT. Is that something I should be worried about?
Old Aug 14, 2013 | 05:06 PM
smokeshow's Avatar
Is this one boosted? Did you have a MAF on your 408?
Old Aug 14, 2013 | 05:08 PM
oakley6575's Avatar
The 4.8L is not boosted yet. Its running N/A. I did have a MAF on my 408 so I only tuned the VE up to 3000rpm or so.
Old Aug 14, 2013 | 05:15 PM
smokeshow's Avatar
The difference between MAF and VE could be part of it. I've also noticed that not all injectors scale the same, which is almost to be expected. So you'd have to make up for the difference in the VE be it higher or lower. Not really an issue. It does change your calculated air mass flow rate though, so that will make your transmission shift differently. Just something to keep in mind.
Old Aug 14, 2013 | 06:10 PM
oakley6575's Avatar
Yea the tranny shifts pretty hard right now. I have it running pretty good. I just haven't seen a VE for a 293 be over 120%. Thanks for your help again.
