help interpreting my log
Old Apr 18, 2018 | 02:02 PM
jstev4610's Avatar
Originally Posted by Last Call
What is your MAP reading with the key on and engine off?
The map reads 90 with key on and engine off. I just pulley'd down yesterday so haven't hooked it up since the initial run. The HP is definitely off, pulley'd down from 87mm to 81mm and now getting 675 at f/t, I'll probably pull it as it's a useless figure. Was curious about the output.
Old Apr 18, 2018 | 03:27 PM
Atomic's Avatar
I have a gauge for that
Where are you located, altitude wise?
Old Apr 18, 2018 | 09:31 PM
jstev4610's Avatar
3,300’
Old Apr 18, 2018 | 11:06 PM
Atomic's Avatar
90kpa (13psi) is your standard atmospheric pressure then. The 14.5 is for sea level ish.
So if your map is reading 18psi then you are actually getting 5psi of boost.
Old Apr 18, 2018 | 11:29 PM
jstev4610's Avatar
sweet, I have my constant wrong. Thank you!
gonzo 6.2
Aug 11, 2013 01:37 PM
2007chevy5.3l
16
Oct 13, 2011 09:34 PM
dimetweaker
Feb 22, 2011 07:54 PM
Yogi Bear
Dec 8, 2008 01:45 PM
InchUp
Aug 7, 2008 11:32 AM
