Help with HP Tuners. 14 GMC trans tune
Want to go to the track Sunday if I can fix this. How do I get rid of the flat spot on the 1-2 shift. I increased the shift rpm to 5800 from 5600. Increased shift mph from 31 to 32. Rev limiter set at 6k. Feels like its same as before at the track like a 1/2 second it just dies at the top of 1st. Same RPM at 2-3 gear does just fine. Help
Thanks Pat I appreciate it sir!
Hmm, I don't have this issue on my 2012 with the same transmission.
It just goes right into 2nd and keeps on going with no delay that I've noticed. I still have TM active so timing drops for all of like .3 to .5 seconds. I've changed shift speed and oncoming pressures and line pressure by a small amount.
Yeah it did it with the stock tune and the Whipple tune and it still is. Only thing from bone stock to begin with is 18" tires instead of 17s.
I understand the 6 speeds are different. Would it help if I upped the shift mph?
Ill go look around thanks
Just not finding anything. Should I try raising the shift mph?
