Help: Found spliced cable coming from Brake Booster
Old Jul 19, 2017 | 11:14 AM
kaze_v8's Avatar
Default Help: Found spliced cable coming from Brake Booster
Can someone help me to figure out what exactly this is, and why it might've been cut?
I noticed it after i did the drop on my truck, and it looks like it was cut and just covered up with electrical tape.
The truck seems to run normal, i will say this, i have had the brake fluid level go low a couple times, but other than that, nothing.
Old Jul 19, 2017 | 11:54 AM
1FastBrick's Avatar
Custm2500's Rude Friend
What year is the truck? That might help.
Old Jul 19, 2017 | 12:09 PM
kaze_v8's Avatar
Iits an 08 Sierra
Old Jul 20, 2017 | 08:26 AM
kaze_v8's Avatar
Anyone?
Old Jul 21, 2017 | 09:58 AM
BigKID's Avatar
Looks to be a fairly heavy gauge wire so likely power to something. Acc power to trailer plug???
Old Jul 24, 2017 | 08:18 AM
kaze_v8's Avatar
Not sure. I see the wire "Y's" into another wire going to the brake booster. FIgured someone could check it out in their truck and see if they have the lines running together.
Might just hook em back up and see if anything happens.
Old Jul 25, 2017 | 02:57 PM
BigKID's Avatar
I don't have anything that looks like that around the booster on my '12 unless it is under the fuse box skirt.
Old Jul 26, 2017 | 01:03 AM
blownescalade62's Avatar
It was for the heated washer fluid that gm recalled or I should say removed.
Old Jul 27, 2017 | 10:06 AM
kaze_v8's Avatar
So you think i should keep it spliced? ANy details or links to that recall?
I dont see how washer fluid heats up..
