Help finding a wire please!!!
Old Jul 12, 2008 | 08:54 PM
vff_jeff's Avatar
Default Help finding a wire please!!!
I nee to find an ignition switched + wire under the hood. I need it to be cold until the key is turned on, then have power... Please help.
Old Jul 12, 2008 | 09:15 PM
KySilverado's Avatar
Under the fuse box. Two large positive posts. One is battery, other is ignition powered.
Old Jul 12, 2008 | 09:25 PM
vff_jeff's Avatar
Ok ill look... Thanx. Can I tell them apart?
Old Jul 12, 2008 | 09:40 PM
You have to take the cover off the fuse block. I've circled the posts. I don't remember which is switched. Multimeter or test light will tell you. Looking at schematics. Alot if not all PINK wires are 12v switched.
Old Jul 12, 2008 | 10:00 PM
vff_jeff's Avatar
Badd ***!!! thanx allot man. I am preety sure its the one closest to the fire wall. But I dont have a tester.
Old Jul 13, 2008 | 09:56 PM
vff_jeff's Avatar
The posts that you show on the picture, One is a constant + the other doesnt read anything on the positive or negative side. I tried with the key on and off, but nothing. But you were right about the Pink wires being switched. I found one next to the pole that was switched. Hydrogen kit is up and running great. Thanx for the help.
greedygenius
Sep 3, 2015 06:51 AM
lxcoupe
17
Aug 26, 2015 05:00 PM
wcrum17841
Aug 24, 2015 08:30 AM
05GMC4.8
Aug 7, 2015 09:55 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
