Help (efilive log)
Been trying to track down a problem for awhile now and may have an idea of what it is. The tune is straight, one that I ran for a long time with no problems before. Can some of the experts take a look and give me an opinion to what you think it is? Note the idle fuel trims...
It is fueling below 4500 hz on the MAF (worse at 3500 and below), why I don't know...if nothing has changed and there is no vaccum leaks, the maf is clean etc.. Try this, 3500 hz and below add 11%, 3500 to 4000 hz add 5%, from 4000 to 4500 hz add 2.5%. Log that and see what it looks like.
That is the million dollar question! If all looks good mechanically and physically with the intake setup then I don't know? I get a lot of people that have weird *** maf readings when they come for a tune, f bodies especially....
Ok, so for the hell of it I went down and got a can of MAF cleaner and sprayed down my MAF real well, let it dry and tried it out.. Nothing was changed in the tune. Here was my results
Note around 20% throttle at around 1300-1400 rpm in Park I get some popping. Sounds kinda like 2 step. I tried to catch it on the log near the end...
As in I wouldn't push more than 50* even in the lightest loads and lowest of rpms. Id stay around 48 or so for this application, for the highest point on the table then blend that in with your higher load settings.
