Help with connector identification
Ok, I'm hooking up all my wiring connectors to my fuse box on my conversion and I have two connectors that I cannot seem to locate where they connect to... don't seem to have a mate connector. Can someone help out an old man?
Truck info. Harness is from a '02 v8 truck, my truck is a '99 and was a v6.
First connector: on the '02 harness located near the fuse box. Has three wires - brown, black w/white stripe and a gray w/black stripe. Looks like it snaps into a hole, possibly on the fuse box case. First pic is one I found on the web, I've circled the connector I'm referring to in RED.
Second connector: on my truck's body harness coming out the cab and is also located at the fuse box. I took pictures as I disassembled and I see this connector on those photos, but unfortunately I took the picture after I unplugged the connector.
After doing more research, I'm "guessing" the first connector (three wired one) is the C153 connector used for 4wd which I can ignore. Thoughts?
Still no idea on the second connector though.
xtrooper89
Sep 21, 2015 06:03 AM
kalikid06
Sep 20, 2015 07:46 PM
