Help with beat to death subject: o2 sensor readiness
Old Feb 6, 2016 | 10:14 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Default Help with beat to death subject: o2 sensor readiness
I know it's beat to death but I'm having issues. I recently started doing my own tuning. I've had the rear o2 sensors deleted for years with other tuners and have always passed. I've driven the truck about 50 miles since the last re-flash. The o2 sensors and heaters won't go ready so I failed today. The rear sensors are unplugged. Even though all the sensor 2 DTC's are set to no error reported should the actual sensors still be plugged in or can they be completly deleted? I need to get those two to go ready. Thanks.
Old Feb 6, 2016 | 10:24 PM
FFDP's Avatar
I didn't have emission testing here but I had to keep the rears plugged in to stop the cat test in the computer from going off everytime I started and ran the truck. It was something you couldn't shut off in my sierra. I wonder if that played a part in the emission part of ready tests.
If you have them, it can't hurt to plug them back in a zip tie them to the frame.
Old Feb 6, 2016 | 11:01 PM
Good call I'll try it out. Thanks.
Old Feb 6, 2016 | 11:44 PM
I wonder how I passed before?
Old Feb 7, 2016 | 06:40 AM
Gadgetized's Avatar
I have my rears completely unplugged. It sounds like they are not fully turned off in the tune. What tuning software? Post your tune so someone can check it over.
Old Feb 7, 2016 | 08:04 AM
George C....'s Avatar
Formerly ScreamingL
Dont need the sensors what so ever, look more into DTC and delete them
Old Feb 7, 2016 | 02:05 PM
I'll keep trying but here's my tune.
File Type: hpt
Old Feb 7, 2016 | 05:55 PM
I was messing around with it a little. I turned off anything to do with sensor 1 heater and the oxygen sensor heater went ready. Do you think I just need to drive it more or was I supposed to turn off all sensor 1 and sensor 2 TDC's? All the other threads I've seen say only sensor 2.
Old Feb 8, 2016 | 09:29 PM
I'm going back in Saturday. Do you guys think I just need to drive it more or does it look like I missed something?
Old Feb 25, 2016 | 12:57 PM
cueball's Avatar
Are you meaning sensors 1&2, or banks 1&2?
You need your sensors 1 but, you can turn your sensors 2 off on both banks.
Once they have been disabled, you need to drive for a little while, usually around 80 to 100 miles after a battery change or pcm reflash before the pcm determines that the rear sensors are ok and the cats are ok.
Hope this helps.
