hard start after flashing tune
Old Aug 1, 2013 | 10:07 AM
sprayedenali's Avatar
Ya, I want to say its in the idle airflow stuff, but idk... Haha
Old Aug 1, 2013 | 10:10 AM
03klugss's Avatar
Originally Posted by sprayedenali
Yup, I'm SD. I wonder if I completely disable whatever code you're talking about it'll fix that..? Like instead of just having it set to no mil report or whatever it's called?
How exactly do you have it setup as far as under the diag. section with the MAF codes?
Old Aug 1, 2013 | 11:02 AM
ill have to look when i get home from work... i dont have a clue
Old Aug 1, 2013 | 11:23 AM
black04's Avatar
Mine stumbles but doesn't die. Always wondered if it was normal.
Old Aug 1, 2013 | 04:45 PM
BLK02WS6's Avatar
9 Second Club
It is likely the idle airflow that needs work... could be other things as well...
You have to have the codes for the MAF set to non-emissions, they can't be set to not reported or it won't even start...
Old Aug 1, 2013 | 06:33 PM
GMCtrk's Avatar
Mine does that as well.
After flashing a tune you need to turn the key all the way to the off position before starting it up.
Old Aug 1, 2013 | 06:42 PM
smokeshow's Avatar
Mod with training wheels
I've had this problem ever since switching to the new version of hpt. SD, stock os, makes no difference. Just takes a little while to clear up.
Old Aug 1, 2013 | 09:51 PM
assuming it is the idle airflow... how do i fix it?!? haha where is the magic buttons to push and make it right?
Old Aug 2, 2013 | 10:27 AM
TXsilverado's Avatar
do a search for russk-Idle-Airflow.cfg and learn how to use it.
Old Aug 2, 2013 | 06:43 PM
LsF-150's Avatar
Mine would start and die multiple times after a reflash until it would finally set the MAF codes, I searched and searched and asked here and hp tuners forum and no one could help me out. I finally figured out Engine>Airflow>Dynamic>Dynamic Airflow>"High RPM Disable" was set to 4000rpm stock, I set that to 0 rpm and now it starts everytime after a reflash, it does stumble for a second intill the MAF codes set, I think that's normal from what I found.
