Had a little accident while tuning today....
Old Dec 6, 2008 | 09:49 PM
BlackGMC's Avatar
Resident Retard
Default Had a little accident while tuning today....
Opps... Tried to log a launch from a stop today, ended smoking the tires and spinning up to 7100rpm and the timing spiked from 26* to 33* Truck seems fine thou, I guess the LS6 springs are a little tougher than most think... BTW it was not intentional, it spun up to fast for the truck to shift normally... Notice how the truck tried to correct itself, notice the 37% TPS....
Old Dec 6, 2008 | 09:53 PM
viciousknid's Avatar
Where's the Beef?
wth is your rev limiter set at?
Old Dec 6, 2008 | 10:01 PM
GMCtrk's Avatar
How accurate do you think those power output numbers are on there? That's a cool touch.
Why do you use EFIlive over HPtuners?
Old Dec 6, 2008 | 10:11 PM
00ChevyScott's Avatar
Wearin' da big hat
*crosses fingers* please blow up please blow up please blow up.
I wanna see that 6 liter swap hehe
Old Dec 6, 2008 | 10:24 PM
2005 Silverado's Avatar
SPAM HUNTER
7109RPM WOWZORS, i was really hoping you got sideways and wet your pants
Dustin
Old Dec 6, 2008 | 11:27 PM
southern_chevy's Avatar
33 is high but not ungodly high. I have had mine around 30 with no knock at 12.5afr but it is back to around 25-27. Why you got the rev limiter set so high? Do that a few more times and that 6L swap might be a have to.
Old Dec 7, 2008 | 09:42 AM
BlackGMC's Avatar
Resident Retard
6800 apparently it did not work...
That is very debatable.... The calculations are setup to measure acceleration, so if they are still increasing then your still accelerating(make power) when they start decreasing then you not going any faster... Nice to use as a ball park to setup shift points...
I have both, I perfer EFI Live due to it's tuning layout and scanner, once again that is debateable.... Each one is fucked up in it's own way...
I shift at 6500-6600 at the track, normally i shift about ~6200-6300... When I go back to the dyno I will see where it stops making power...
Old Dec 7, 2008 | 10:11 AM
v8
17,16,15,14,13,12,11 Drvr
That's not bad corey, mine sees that every day 33 degrees&7000rpms hahaha
Old Dec 7, 2008 | 08:07 PM
mdwatts11's Avatar
I just had my truck tuned by BlackBear and it was hitting 55* of timing on a stock tune. I wasn't giving it fuel or anything, why does this make me worry?
Old Dec 7, 2008 | 08:18 PM
Wearin' da big hat
55* at idle?
