got a problem??
when at the track fri. night my truck was throwing a code and showing reduced engine power in the message center. it was shutting the truck down before i could get halfway down the track. and it seemed like it was running on 2 cylinders afterwards. but when i killed it and cranked it back up it would be fine until i tried to make another pass. the code was U0107 lost communication with throttle body acuator switch, or something real close to that. does anyone know the problem with this or has anyone had this same problem. this just started doing it since the headwork and bigger cam. and it seems to do it worse with the cutouts open, and it does it real bad when i pull the passenger headlight out. all help is greatly appreciated.
Originally Posted by jmproductions
How do you know???
