got a code with headers...
Old Feb 12, 2008 | 12:42 PM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by Truckshop
most high flow cats are not efficient enough to pass factory emmissions. get the codes deleted with tuning and it will be just fine.
Would be the first I have heard of dynatechs having an issue to not effect the rear sensor
Originally Posted by Wheatley
P0420 and P0430 needs to be disabled in the PCM if you run no cats
He's running the complete dynatech system as far as I read, has cats included in the setup, albeit "high flow". I said albeit twice in this thread now
Old Feb 12, 2008 | 12:47 PM
Allgonoshow's Avatar
i have the dynatech cats installed
i moved the rear 02 ahead in the pipe to eliminate the pigtail extension and get the 02 ahead of the exhaust stream from the drivers side pipe, it was close to the point where the 2 pipes y-together, the flow from the other pipe may have caused an issue with the reading too, who knows. it won't now.
also, you can't mix up the front and rear oe 02 plugs, but the extension has a male and female end so it would be possible to plug the 02's in wrong with the extension.
thanx for the quick input guys...
Old Feb 14, 2008 | 09:38 AM
Avalanche2002's Avatar
I had the same issue on my Vette when I put the Dynatech system on and it was the rear passenger side.
I tried just resetting the codes for a while to see if the tune would adjust to the Dynatechs; it did get longer between throwing codes but it never completely stopped. We have emissions testing in St. Louis so I had to stop the codes; I ended up putting O2 sims on in order to get my code to go away since I didn't have a tuner to shut the codes off.
Old Feb 15, 2008 | 03:40 PM
3 days, same light after moving sensor and eliminating extension.
anyone know if you can change the thresholds with hpt for the sensor, or if i just gotta turn it off.
if i turn it off, any down side for tuning/performance?
does it go to default values or what.
i'd like to have the light out so if something else comes up i'll know...
Old Feb 15, 2008 | 05:41 PM
TURBHOE's Avatar
no down sides for tuning/performance. no down sides of any that i know of.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
