going to dyno tommorow / need lock up help
Old Jan 4, 2007 | 09:02 PM
Tahoe6.0's Avatar
Default going to dyno tommorow / lock up / update results
How do you lock up converter in third gear on the dyno? My 1st time doing this, ineed some baseline numbers to work with. Thanks for your help.
Old Jan 4, 2007 | 09:18 PM
Blown02Sierra's Avatar
W/ efilive i know you can w/ the bidirectional controls. Aside from that, i have no clue.
Old Jan 4, 2007 | 09:20 PM
Tahoe6.0's Avatar
Can you do it with a snap on scanner in trans mode? Have a nelson tune, or just run it and see what it does?
Old Jan 5, 2007 | 07:40 PM
Wheatley's Avatar
Truck Sponsor
They will put out alittle better numbers with it locked.I have always locked them on the dyno.
Old Jan 6, 2007 | 10:14 PM
Tahoe6.0's Avatar
Default Update / Went to dyno today, first time ever
I finally made it to the dyno for the 1st time with LQ4. Engine has custom cam, 218 .576 114+2, Milled heads .030, 041 gasket, 10.0 to 1 comp. Corsa Cat back and Nelson tune. 298 RWHP 316 RWTQ, What do you guys think? Is this good for what I have? Does it look like I need Headers and Heads so upper horse power doesn't fall like a rock. I need some help please! Will have to try and get in touch with a tuner also! Maybe change some timing and air fuel first? The only good thing was that awesome chevy Corsa sound pulling on the dyno. Sound clip next time!
Old Jan 6, 2007 | 10:30 PM
Rhino79's Avatar
9 Second Club
Your power should not fall off like that.....might need a good street/dyno tune.
Old Jan 7, 2007 | 10:53 AM
chrisj6's Avatar
He's right, i had that problem in my Z71 and it was timing/AF related.
jscherbs
Mar 24, 2017 07:20 PM
jscherbs
Sep 30, 2015 07:54 AM
Chevy305
Sep 28, 2015 09:21 PM
dselby25
Sep 11, 2015 05:03 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
